Linpus comes with a modified version of the xfce4-panel (the taskbar) called xfce4-panelnew.
This version prevents you from modifiying the taskbar to your needs (usually you can right click on it to get menu).
- press Ctrl + Alt + Del to bring up system monitor
- search xfce4-panel process and end it (the taskbar disappears, don't get worried)
- press Alt + F2 and run xfce4-panel.old. This brings up the original Xfce panel, slightly misconfigured but you need it only for configuring your taskbar.
- Now you can right click your taskbar and Add plugins. A window with all installed xfce panel plugins is opened.
- Select your preferred plugins by drag&drop them onto the taskbar. e.g. use Xfce Menu
- Now use the same steps to end the process xfce4-panel.old as described above.
- press Alt + F2 and run xterm. In terminal type "xfce4-panel &".
- Now you should have the previous panel back and your configured plugins like the attachment
The Xfce menu on the taskbar is much more easier to handle than the right-click menu (its the same)!
You can install additional plugins through the Package Manager! Navigate to Desktop -> Xfce -> Optional Packages
and choose the ones you like (some plugins are not correctly displayed on the panel).
gr33tz,
Tybor
