iDeneb v1.4 10.5.6 Install guide
Postby diablonet » Wed Feb 25, 2009 9:25 pm
iDeneb v1.4 10.5.6 on Acer Aspire One (AOA150 1100)
by diablonet, thanks to SbM for his original work!!
25/feb/09
Mazatlan, Mexico
PARA INSTRUCCIONES EN ESPAÑOL VISITA / FOR SPANISH INSTRUCTIONS VISIT
http://webmaster-mexico.com/macosx-1056 ... one-AOA150
As far now:
Software Updates as real mac - WORK
Wireless card work changing the Internal PCI-E with a DW1390 or DW1490.
Sound Input (Mic, Line in not tested) and output (speakers and headphones with autoswitching) - WORK
Full ISO Keyboard - WORK
USB 2.0 - WORK
Sleep - DO NOT WORK
Shutdown (without kernel panic on battery mode) and restart - WORK
Card readers, Just SD - WIP - http://osxsdhci.sourceforge.net/
Video card (Mirroring, External monitor and full acceleration) - WORK
Battery recognition - WORK
Webcam - WORK
Wired Network - WORK
HyperThreading (Voodoo kernel is installed by default) - WORK
1.- Download iDeneb 1.4 from your favorite download site. (dont ask me where)
2.- Burn it at low speed, use good media and verify after burn.
3.- Insert DVD on External USB Drive.
4.- Turn on aspire one and hit F12 key.
5.- Boot from USB External DVD Drive.
6.- Wait for boot process.
7.- Click the button "-->" to continue, then "agree"
8.- Click on utilities / Disk Utility.
9.- Optional - Erase your actual data if you want to with right mouse click on partition then "Erase" and quit Disk Utility and run it again.
10.- Click on your hard drive, then "Partition", Volume Scheme "1 Partition", Name it: "Macintosh HD" for example, Options "Master Boot Record", "Apply", "Partition", quit Disk Utility.
11.- Select your disk then "Continue".
12.- "Customize", select only "Netbook-> Acer Aspire One A150" + "iDeneb Essential System" and if you need to, "Language Translations-> Your favorite language" (I did for Spanish).
13.- Hit "Install" then (Optional) click on disc verification "Skip".
14.- Wait for installation, it will restart when it finishes.
15.- During the boot process you will see the "Darwin boot" you must press any button and write on boot: "-x" (without quotes). If you miss this step you can manually shutdown and repeat this step.
16.- Follow the required data. (Select the ISO keyboard and set a password for your account).
17.- Login with your password.
19.- Download Diablo's iDeneb 1.4 tools from http://webmaster-mexico.com/ideneb-v1_4 ... instalador extract it and install "DoNotSleep"and "GMA950" packages and reboot.
20.- Go to system preferences->energy saver, set both options to NEVER on power adapter and battery profiles.
21.- OPTIONAL - Full ISO Keyboard fix:
In the tools files, there is a folder "Keyboard ISO" inside of it there is a file called ApplePS2Keyboard.kext copy it into /System/Library/Extensions/ApplePS2Controller.kext/Contents/PlugIns/ to replace the original one.
(right click on /System/Library/Extensions/ApplePS2Controller.kext "Show package content")
BE CAREFUL: don't install it in /System/Extensions/ but INSIDE the ApplePS2Controller.kext you'll find there.
Open Terminal and type:
sudo su
(type username password)
chown -R root:wheel /System/Library/Extensions/ApplePS2Controller.kext/Contents/PlugIns/ApplePS2Keyboard.kext
chmod -R 755 /System/Library/Extensions/ApplePS2Controller.kext/Contents/PlugIns/ApplePS2Keyboard.kext
rm /System/Library/Extensions.mkext
22.- From the tools files, copy the folder ShutdownSound into /Library/StartupItems
23.- From the tools files, run OSX86Tools and enable Quartz GL and reboot (If after the boot process it ask for fix something, just hit FIX)
24.- Run in terminal "diskutil repairPermissions /"
25.- Enjoy!
Update 1: Fix for slow boot thanks to buddy90210 for pointing this
If a SDHC card is inserted after installing iDeneb v1.4 it makes extremely slow boot, if the card is removed, it would boot fine, so you can remove the following files and it would boot fine with the SDHC card still in place.
/System/Library/Extensions/IOSDHCIBlockDevice.ktext
/System/Library/Extensions.ktext
diablonet
Re: iDeneb v1.4 10.5.6 Install guide
Postby magnatree » Wed Feb 25, 2009 10:37 pm
Thanks a lot! Works great! :-)
Will hibernation with Smartsleep work? Didn't tested yet...
magnatree
Postby diablonet » Wed Feb 25, 2009 10:44 pm
Not tested, but dont get too excited about it :D
diablonet
Postby AK963 » Thu Feb 26, 2009 7:40 am
So, If i was installing OSX would this be a better option than iATKOS? Seems like less steps.
White AAO A150 - 3 Cell, Atom @ 1.6GHz, GMA 950 @ 400MHz, 1GB RAM, 120GB HDD, Mac OS X 10.5.8
White HTC Sapphire, Froyo
Check out netbook-gaming.co.uk, a database of games suitable for netbooks submitted by the community.
Blog|Twitter
AK963
Postby magnatree » Thu Feb 26, 2009 8:46 am
It's the best distro I've tried so far, so I think so AK963 ;)
magnatree
Postby DutchAcerOne » Thu Feb 26, 2009 9:17 am
Great tool to clean up unused files, and for free!
http://www.omnigroup.com/applications/omnidisksweeper/
DutchAcerOne
Postby diablonet » Thu Feb 26, 2009 1:25 pm
If its not the best distro at least its much easier!
diablonet
Postby RottGutt » Fri Feb 27, 2009 2:14 am
Has anyone successfully used this .iso to make a boot USB drive? I was able to use ddmac.exe with the iATKOS .iso, but have been unsuccessful after a dozen attempts with the iDeneb .iso.
RottGutt
RottGutt
Postby magnatree » Fri Feb 27, 2009 10:35 am
If you have a running OSX it is really simple: Just follow this short guide: http://www.insanelymac.com/forum/index. ... pic=154853
If not, well, i tried about 3 days to do it, but no success...
magnatree
Postby magnejuul » Fri Feb 27, 2009 2:23 pm
Thanks!
This is by far the best "distro" I have used.
magnejuul
