iDeneb v1.4 10.5.6 Install guide
Re: iDeneb v1.4 10.5.6 Install guide
Postby RottGutt » Fri Feb 27, 2009 3:05 pm
magnatree wrote:If you have a running OSX it is really simple: Just follow this short guide: http://www.insanelymac.com/forum/index. ... pic=154853
If not, well, i tried about 3 days to do it, but no success...
Thanks, Magnatree, that worked great! Ironically, it was the 3rd way of creating the USB Boot Drive that I tried. 3rd time's a charm, right? As an FYI, my first USB thumb drive did not work for any version of OS X, but I tried a 2nd thumb drive (SanDisk Cruzer micro 8 GB), and had success. I hope it helps.
RottGutt
RottGutt
Postby chuckcalo » Fri Feb 27, 2009 3:09 pm
I think the best distro for the Acer is the iPC since it supports Hibernation.
Can anyone tell us if Hibernation is working with this distro ?
AAO 150 - 120GB / 9 cell (DW 1390)
chuckcalo
Postby magnatree » Fri Feb 27, 2009 4:26 pm
Doesn't work. At least not with the described steps for the iPC distribution. Kernelpanic.
magnatree
Postby DynaMight » Sat Feb 28, 2009 1:34 pm
I followed this guide last night and every installed fine. I havent got my Dell wireless card yet so using a compatible USB one atm, I haven't tried hibernation but I'm not that fussed. Everything else seems fine.
Triple boot WinXP/Win7 and OSX. All working fine.
DynaMight
Postby sean808080 » Sat Feb 28, 2009 4:50 pm
I made every mistake possible but finally got this thing running. it's all a lesson as far as I'm concerned. Thanks much for posting this.
sean808080
Postby diablonet » Sat Feb 28, 2009 4:58 pm
Glad it work for you, you welcome!
diablonet
Postby JJones_86 » Sat Feb 28, 2009 8:10 pm
Hello, I just finished installing and I am a newbie to macs, but my wireless is not being recognized. It seems like I can only use the ethernet.. Any suggestions?
JJones_86
Postby JJones_86 » Sat Feb 28, 2009 8:59 pm
lol, well i found out the wireless wont work unless you buy a different pci card, so I got one off of ebay but my ethernet isnt even working? I plug it in an nothing shows up...
JJones_86
Slow Boot Time
Postby buddy90210 » Sat Feb 28, 2009 11:34 pm
What boot times should I be expecting?
I have a AAO-150 (160GB HDD), followed the instructions with the except of the optional keyboard change and I'm getting the following boot times:
OSX Boot
Elapsed Time: Event
0:00: Darwin Bootloader
0:10: Apple Logo
1:10: Blue screen
5:30: Login screen
5:45: Login complete
OSX Boot with -x
0:10: Apple Logo
1:00: Blue screen
1:15: Login screen
1:35: Login complete
Shutting down takes about ~15 sec
Booting Win7 seems to take ~20-30 sec so I can't see this being a HDD problem. Could this be due to the stock wirelesscard?
Any suggestions would be greatly appreciated!
buddy
Edit: FYI - I started a new thread for this topic here http://www.aspireoneuser.com/forum/viewtopic.php?f=14&t=11936
buddy90210
Postby webmaster mexico » Mon Mar 02, 2009 11:30 pm
I followed this guide and every installed fine.
Thanks Diablonet!!
This is by far the best "distro" I have used.
webmaster mexico
