10.5.7 install on Acer Aspire One D250 using iAtkos v7
Postby bigplrbear » Tue Jul 28, 2009 5:32 pm
Hey all, this is my first post :]
Anyways, here's what you need to select in iAtkos v7 to make this work-
Chameleon bootloader v2
DSMOS as the decrypter (DESELECT APPLEDECRYPT)
Kernel Voodoo 9.7
x86 ACPI
intel GMA 950 desktop, laptop and rare
Voodoo HDA (sound)
Apple PS/2 controller
System -> laptop battery
everything else should be left alone
1st boot- Boot with cpus=1 -v -f, set up your system, reboot
2nd boot- Boot with same flags as above, dload Kernel Voodoo 9.5 (or Voodoo 2 alpha) from google code and install (the provided voodoo kernel has a tendency to panic w/ out cpus=1 flag for some reason)
3rd boot- Boot with -v flag, just to be safe ;). Delete seatbelts.kext from /system/library/extensions (prevents kernel panic when you're opening a .dmg)
4th boot- You're good to go :)
Things that don't work-
Webcam
Internal wifi (i'm using a USB wifi adapter right now)
Things that work-
everything else
Untested-
Mic
Good luck!
*note- processor comes up as 2xCore Solo. Core Solo = no 64bit support = no snow leopard for you!
iBook G4 w/ 1.5GB of RAM. 10.4.11 Tiger
AAO D250 w/ 2GB of RAM. 10.5.8 Leopard
Core2Quad desktop w/ 2GB of RAM. Win 7 64-bit
Website -> http://bigplrbear.com
Twitter ->http://twitter.com/bigplrbear
Facebook -> http://facebook.com/bigplrbear
Blog -> http://bigplrbear.tumblr.com
bigplrbear
Re: 10.5.7 install on Acer Aspire One D250 using iAtkos v7
Postby Ale-xs » Wed Jul 29, 2009 8:21 am
Sleep not work
Int mic not work
ethernet not work
wi-fi not work
post installation actions:
boot with -s
/sbin/mount -uw /
rm -rf /System/Library/Extensions/IO80211*
rm -rf /System/Library/Extensions/io80211*
rm -rf /System/Library/Extensions.mkext
reboot
and cpus=1 and kernel update not needed anymore
Ale-xs
Postby aquafloe » Thu Jul 30, 2009 11:29 pm
Have you tried using the VoodooPS2Controller yet? It works somewhat, but it seems there are still instances of ApplePS2 that I can't remove that are screwing it up.
aquafloe
Postby PhAndrew » Fri Aug 07, 2009 5:31 pm
can anyone revise this tutorial please? like what works what doesnt and also the latest guide to install os x on a d250
Blue D250 / 2 gigs ram /windows 7
PhAndrew
Postby mappy » Tue Aug 18, 2009 5:53 am
This guide pretty much worked for me and I have a pretty stable D250 running OS X 10.5.7.
Did anybody found a way to get the wired network to operate?
Same question for the wireless? I use a USB one so far but that would be so cool to get those 2 things fixed.
The sleep option too but I can live without this, it's more difficult to live without network.
Any insight greatly appreciated. After hours of research it looks like there are solutions for D150 but nothing so far for the D250.
Mappy
mappy
10.5.8 install on Acer Aspire One D250 using iAtkos v7
Postby bigplrbear » Thu Sep 03, 2009 1:53 am
Okay, after lots of toying around, here's a badly needed update-
*EDIT- I forgot to mention something- in this tutorial, I'm assuming you're using a USB DVD drive.
However, the procedure isn't much different if you're installing from a flash drive/memory stick
Before installing, do the following-
Download the Apple COMBO update (~750MB) for 10.5.8 on to a disc or flash drive.
Download the D250.zip file that I prepared. It comes with-
-Kextloader B7
-Atheros 5007EG drivers
-Kismac 0.2.99
-VooDoo 2 alpha 3 kernel (you may install an alternate kernel if you wish, however hyperthreading might not work. Your mileage will vary)
Now-
1.Insert your iAtkos disc and boot from it
2.Format your disk. MAKE SURE IT IS SET TO MBR (GUID partition schemes tend to corrupt over time on this netbook)
3.In the 'Customize' menu, select the following-
Main System -> Bootloader -> Chameleon 2
X86 patches -> Decrypters -> dsmos (uncheck 'AppleDecrypt')
Kernel -> 9.5.0 voodoo
ACPI -> x86 ACPI
GFX -> Intel GMA 950
Sound-> Voodoo HDA
System -> Apple PS2 controller (voodoo PS2 w/ trackpad is optional, but has a tendency to stop working and cause kernel panics)
System -> Laptop battery (NTFS-3G and ExtFS work as well if you want them)
you may also install an alternative language to English
*EDIT- Uncheck 'Disabler'. Disabler.kext WILL mess up your 10.5.8 install and make your system ubootable.
4.On first boot, use the following flags-
-f -v cpus=1
5.Go through the video, cheesy music (don't worry about the sound cutting out randomly- this is due to the cpus=1 trick), username, etc.
6.Unzip the D250.zip file somewhere. Use OS x86 tool to install the VooDoo Alpha 3 kernel. Reboot w/ no flags (well, -v if you're curious). You MAY get a kernel panic- just reboot again if that happens.
*EDIT- after you install the kernel, install system.kext and seatbelt.kext files for kernel version 9.5.0. You can find these via google or insanelymac.com
7.Backup kexts like so- 'sudo cp -rf /System/Library/Extensions /System/Library/Extensions.backup'
8.Backup kernel like so- 'sudo cp -rf /mach_kernel /mach_kernel.backup'
9.Now, install the 10.5.8 Combo update that you downloaded earlier. DO NOT REBOOT.
10.Open up OSx86 tool and select "Repair permissions", "Set Extensions permissions" and "Clear Extensions Cache". wait for it to finish
11.NOW reboot. It will reboot once or twice on it's own- don't fret! Once it's done, you should be back to your desktop with an ugly 800x600 resolution or a blue screen.
12.Turn off the computer, insert the iAtkos v7 disc, boot from it, and select ONLY the Intel GMA950 driver
13.Reboot once more, and you should be back at your desktop with a nice 1024x600 resolution again.
14.Now that that's done, open up the AR5007EG.pkg file. Reboot.
15.Open Kismac, go to preferences and add "Airport Extreme passive". Now scan- you should see some networks. :D
And that's about it. You now have a D250 with 10.5.8. STAY AWAY FROM AIRPORT UPDATES. All other updates are fine to install.
Remember- when you reboot, your wifi might break. If that happens, try rebooting with -f. Chance of it working after reboot- Not very high.
Suggestion- invest in a new PCI-e wifi card ;)
Make sure to DISABLE SLEEP. It causes a silent kernel panic.
Things that don't work- Web cam, ethernet (Attainsec Gigabit rev 0c), sleep/hibernate
Untested- mic
*note on the whole Snow Leopard thing- Snow Leopard *should* work, because it *is* 32-bit compatible. Good luck getting it to install on an MBR HDD. If/When I try out Snow Leopard (probably after the release of 10.6.1), I'll post another tutorial for it. [update 10/17/2009- Snow Leopard is really fu**ing buggy. Looks like I won't toy with it for quite a while]
Also, a screenshot-
bigplrbear
Postby PhAndrew » Thu Sep 03, 2009 5:38 pm
omg.... its a beautiful :D a nice guide for the d250. thank you very much! wat is ur bios v? is there any need to update it?
PhAndrew
Postby bigplrbear » Thu Sep 03, 2009 6:06 pm
PhAndrew wrote:omg.... its a beautiful :D a nice guide for the d250. thank you very much! wat is ur bios v? is there any need to update it?
I haven't even touched the BIOS lol
bigplrbear
Postby PhAndrew » Fri Sep 04, 2009 12:28 am
which PCI-e wifi card did u get?
PhAndrew
Postby twilight79 » Fri Sep 04, 2009 1:24 am
Hi guys,
i am desperate to get os 10 onto my d250 but feel unconfident!!
can someone please please post a step by step tutorial to make it easy for every 1???
your help would be greatly appreciated!!!
i think the video would be so good because there are sum complicated bits such as entering "key commands" etc which some people like me might not follow!!!
thanks much in advance
cheers
twilight79
Users browsing this forum: No registered users and 3 guests
