TUTORIAL(EDITED APRIL 5th 2010)
What You Need:
•8gb or bigger external USB Hard Drive
•Mac Os X running hardware: MacBook, MacBook Pro or other
•AO751h
•Mac OSX 10.6 Disk
•10.6.2 combo update http://www.apple.com/downloads/macosx/a ... combo.html
•10.6.3 combo update http://support.apple.com/downloads/DL10 ... 10.6.3.dmg
•Windows 7 (for dual boot) and External DVD USB drive
•NetbookBootMaker 0.8.3rc5 http://netbook-installer.googlecode.com ... C5.app.zip
•NetbookInstaller 0.8.4pre http://netbook-installer.googlecode.com ... re.app.zip
•AppleIntelPIIXATA.kext size 250kb from here http://www.mediafire.com/?jmkgrgkjeyi
•VoodooHDA.kext size 537 KB http://www.megaupload.com/?d=F7AM6TV4
or here with others http://www.megaupload.com/?d=VMLE4MNC
On Mac:
1. Click on NetbookBootMaker 0.8.3rc5.app and choose show package contents. Search for AppleIntelPIIXATA.kext files in contents. Replace three of them with 250kb one You downloaded before. Should be here
NetbookBootMaker 0.8.3 RC5.app/Contents/Resources/SupportFiles/machine/Dell Mini 9/10.6 Extensions
NetbookBootMaker 0.8.3 RC5.app/Contents/Resources/SupportFiles/machine/Dell Mini 9/10.5 Extensions
NetbookBootMaker 0.8.3 RC5.app/Contents/Resources/SupportFiles/machine/General/10.6 Extensions/IOATAFamily.kext/Contents/PlugIns
2. Prepare Your 8gb usb drive according to mechdrew instructions http://osx.mechdrew.com/guides/nbi1.shtml
3.Run NetbookBookMaker 0.8.3rc5 and choose as target: Mac Os x Install DVD. Let it successfully patch Your usb hd. Close NBM and eject usb drive
On AO751h:
1. Take out Your battery. Plug Your NBM USB hd, don't plug other usb devices.
2. Power on AO751h push F2 to open bios/main enable F12 Boot Menu, F10/Yes to save and reboot with F12 to chose USB hd.
3. You will see Apple logo and after some time Installation language setup. Choose Your language and accept to go to Disc Manager from Installation menu. Choose 1 partition setup (2 partitions if You want to have dualboot with Windows 7, make second fat partition) Mac Os X extended (Journaled) GUID Partition Table. Press Apply, then Partition. When it is finished, close Disk Utility.
4. Select Your new mac partition and customize what You want to install. Install. AO751h should reboot automatically.
5. Fix sound: Open system/library/extensions -remove AppleHDA.kext(create a backup!) -copy VoodooHDA.kext. Internal or external(mini jack) mic is still not working (Only external usb mic works). Run NetbookInstaller (0.8.3rc5) from Your applications. Reboot.
6. Download NetbookInstaller 0.8.4pre http://netbook-installer.googlecode.com ... re.app.zip
7. Click on NetbookInstaller 0.8.4pre.app and choose show package contents. Search for AppleIntelPIIXATA.kext files in contents. Replace two of them with 250kb one You downloaded before. Install NetbookInstaller 0.8.4pre
8. Reboot.
9. For better video install Perian http://perian.org/
10. For WIFI internet You can buy usb mac dongle- 14$.
11. Upgrade to 10.6.2 - use combo update don't restart yet.
12. Install NetbookInstaller 0.8.4pre after update again. Reboot.
You can update to 10.6.3 only if You have access to /System/Library/Extensions via second partition (I'm using win7) or other way
13. Upgrade to 10.6.3 - use combo update don't restart yet.
14. Install NetbookInstaller 0.8.4pre after update again. Reboot.
15. You should try to run once with nbi safe mode: -x, -x -s -v options (use shift during start) and found that machine was "waiting for root device". Reboot in Windows 7 or other You are able to edit kext in /System/Library/Extensions on Your Mac partition
16. Now You should access Your mac partition, I'm using windows 7 partition system and macdrive to delete the IOATAFamily.kext from /System/Library/Extensions ( I was trying to delete it after step 14. before reboot but didn't work )
17. After delete IOATAFamily.kext from /System/Library/Extensions boot in safe mode: push shift on boot after partitions icons appear write -x ( I found this trick on MyDellMini forum - work on ao751h with NBI8.4pre only)
18. You will see progress bar after some time and You will see that hd is finally reacting. In safe mode reinstall NetbookInstaller 0.8.4pre and reboot.
19. For sound run Update extra app and run it twice.
20. Reboot - in 10.6.3
Installing win 7
1. Power on AO751h push F2 to open bios/main enable F12 Boot Menu, F10/Yes to save and reboot with F12 to chose Windows 7 disc in DVD drive.
Change fat partition into ntfs and install. After reboot You should be able to choose boot partition with Chameleon if not restart in Windows open command prompt (start accessories) and write:
DISKPART
select disk 0
select partition 1
active
now when you restart you will see chameleon.
I HAVE INSTALLED AND REINSTALLED WITH MY SAME GOOD OLD 8GB USB PENDRIVE 10.6.0 NetbookBootMaker 0.8.3RC5 ABOUT 100 TIMES AND DIDN'T ERASE ANYTHING TO KEEP MY WORKS ALIVE SO YOU CAN JUST CHOOSE TO COME BACK TO OLD 10.6.0 ANY TIME IF YOU KEEP YOUR USB DRIVE AS SAFETY! YOU CAN ONLY REINSTALL NETBOOKINSTALLER FROM 0.8.4PRE AND 0.84RC1 TO 0.8.3RC5 FROM APPLICATION SECTION OF INSTALLER WHEN YOU ARE ON 10.6.0, 10.6.1, 10.6.2. IF YOU NEED TO COME BACK FROM KP OR OTHER ERROR ON 10.6.3 YOU NEED TO INSTALL 10.6.0 BUT DON'T ERASE YOUR PARTITION JUST REINSTALL IT CHOOSING SAME THINGS - IT WILL SHOW LESS SPACE REQUIRED AND TAKES LESS TIME. AFTER SUCCESSFUL RE-INSTALLATION NEED TO RUN NETBOOKINSTALLER 8.4PRE AGAIN.
YOU MAY NEED TO MAKE ACTIVE YOUR WIN/MAC PARTITIONS AFTER USING NBI 0.8.3RC5 WITH YOUR WINDOWS 7 INSTALLATION DISC - USE REPAIR/COMMAND PROMPT:
DISKPART (enter)
select disk 0 (enter)
select partition 3 (enter)
active (enter)
reboot
after restart,start again with cd,it will now tell you to repair and restart,
if not choose it your self
now you can enter in windows after reboot.
in windows now:
open comand prompt (start accessories) and write:
DISKPART
select disk 0
select partition 1
active
I followed instructions from: http://code.google.com/p/netbook-instal ... ed_Devices
Comment by camrstac12, Jan 05, 2010
Thanks for your efforts guys! I am making progress getting AA 751H running; using the USB method the installer (10.6.0) fires up sweetly but no hard disk is seen. After a lot of testing I have found a AppleIntelPIIATA kext that appears to work, could anyone you a hint how to get that used in the USB method installer?
Comment by camrstac12, Jan 06, 2010
Update on Acer Aspire 751: use the USB method but copied the AppleIntelPIIATA.kext from the Dell Mini 10 thread to NetBootMaker?.app, install went OK 10.6 running with 1366x768, No Wifi failed to get the AR5001 going, have just bought a AppleAirport? for £20 to replace it. RealTek? works just fine. WebCam? is seen on the USB bus but doesnt work, nor does the sound, but since the Dell Mini 10 uses the same chipset it ought to work. Just updating to 10.6.2 (fingers crossed).
Comment by camrstac12, Jan 11 (6 days ago)
http://www.mydellmini.com/forum/general ... opard.html grab the mini 10 support files. Grab the AppleIntelPIIATA.kext; replace this kext in the netbookbootmaker.app (just look inside the pkg to find where to put), then follow the instructions for USB key with MAC.
Tried same and my 751 is SL 10.6.2 now
There is sound, Ethernet, no wifi and no mic still.
I'm connecting via iPhone as modem to internet
I'm sure there is some way to use as wifi modem too. Still searching.
So good luck
