Fix for audio auto-switching
Postby amf5 » Thu Oct 16, 2008 5:17 am
Firstly, I'd like to mention that this method is not completely my own - I figured this stuff out through a little digging and adapting other people's methods to suit the AAO.
To fix the audio auto-switching problem:
1. If you haven't done so already, I highly recommend using the Voodoo kernel 9.5 beta 2; I've found it improves performance (specifically over the ToH kernel installed by default with iATKOS) and fixes a few things with hyperthreading and SpeedStep if you've got that kext installed.
2. If you're using the ALC268FIX package provided in the iATKOS thread, delete AppleAzaliaAudio.kext and AppleHDA.kext from /System/Library/Extensions. You may also need to delete the "Taruga" folder (I didn't run HDA Fix, so I didn't do this step).
3. Contrary to the other method, I've found that ALCInject.kext is actually necessary for auto-switching (I might be wrong on this one though). If you don't have it already, get it here. HDAEnabler may also be necessary, but again, I'm not sure on this one.
4. Install AppleHDA.kext from here.
5. Reboot. You'll likely notice a noise coming from the speakers - that's because the microphone is enabled. Go to System Preferences, then sound. Go to the "Input" tab, select "Internal microphone" and lower the input volume all the way.
That should be it! Auto-switching between headphones and the internal speakers works perfectly for me, as does shutdown.
amf5
Re: Fix for audio auto-switching
Postby rory » Thu Oct 16, 2008 8:19 am
The next question from the community is going to be "Is line in working?"
Rory
Postby jANjALANi » Sun Oct 19, 2008 11:23 pm
Thanks amf5! It works! now my AA1 is almost perfect...
if it weren't for Vga Mirror & Sleep problems my AA1 is almost perfect
jANjALANi
Postby SticMAN » Thu Oct 23, 2008 2:46 pm
Is anybody's internal mic working?
StiCMAN
edit: I fixed it!!! I now have Autoswitch and internal MIC, I disabled the external MIC(pink on left side) as it was playing directly through the speakers!
SticMAN
Postby phampton81 » Wed Oct 29, 2008 6:01 am
I am interested in trying out the voodoo kernel, but am having trouble finding simple instructions for swapping my kernel. If anyone could point me in the right direction I am more than willing to learn how to do it through a bit of reading, I am just having trouble finding the right place to start/look.
phampton81
Postby amf5 » Wed Oct 29, 2008 7:41 pm
phampton81 wrote:I am interested in trying out the voodoo kernel, but am having trouble finding simple instructions for swapping my kernel. If anyone could point me in the right direction I am more than willing to learn how to do it through a bit of reading, I am just having trouble finding the right place to start/look.
Assuming you put the voodoo kernel file in the root of your hard drive, go into Terminal and type in the following:
sudo su
cd /
cp voodoo_beta2 /mach_kernel
Simple enough really.
Alternatively, if you don't want voodoo to be your default kernel, you can boot with it by entering "voodoo_beta2" as a boot argument (no quotes, obviously).
amf5
Postby jANjALANi » Wed Oct 29, 2008 8:00 pm
or you can use OSX86Tools, it has features like Backup Kernel, Restore or Install Kernel
jANjALANi
Postby phampton81 » Thu Oct 30, 2008 4:26 am
voodoo kernel installed, thanks for the help. Only just installed it, but my impression is that it is a bit better, I was getting some random 1-2 second hang-up/pauses (and the occasional beach ball) while web surfing or general use, which seem to be gone now.
phampton81
Postby Drillbit » Thu Oct 30, 2008 8:59 pm
I did as listed but not it says that - no input devices found - no output devices found.
Any ideas?
I used the MSIWindOS86 install.
Drillbit
Postby amf5 » Thu Oct 30, 2008 9:22 pm
Drillbit wrote:I did as listed but not it says that - no input devices found - no output devices found.
Any ideas?
Was sound working before? The Wind has a different sound card than the AAO.
amf5
