wireless problem all lost
Post regarding making a new connections or questions about Home / Office Networking and WiFi
Postby Frits » Mon Jul 28, 2008 5:27 pm
Hello, here's a new user from the Netherlands.
Love the small thing!!!
Only, after i switched the One on for the first time i saw trough the internetconnect icon on the bottom right several wireless networks in my neighbourhood. After i applied the Live updates i lost the list off networks. I still can connect through cabel. Also, when i use the switch on the front to activate the wireless mode, the icon appears in my screen, but i can't see the networks. Also the led isn't burning anymore.
Anyone a solution???
Frits
Re: No list of networks wireless
Postby petch » Mon Jul 28, 2008 5:39 pm
It won't help but you are not alone. It happenned to me and I am still looking for a solution. I plan to restore my aspire one but it's not an esy task too...(need for an external driver)
petch
Postby Frits » Mon Jul 28, 2008 5:52 pm
Oke, so i am not the only one. I don't see the wireless icon( the antenna) apearring when i switch one the wireless switch..
Hope someone has the answer..... :roll:
Frits
Postby nngomes » Wed Jul 30, 2008 10:01 am
Im on this boat too... maybe the acer updates did this!
nngomes
Postby Frits » Wed Jul 30, 2008 2:15 pm
I did the recovery thing, but it didn't work.
I still can use cable, but don't see any wireless networks..... :(
Frits
Postby nngomes » Wed Jul 30, 2008 4:19 pm
this is becomig a REAL issue... more and more people are having this problem.
Any linux experts here that may help?
nngomes
Re: wireless problem all lost
Postby drvolk » Thu Jul 31, 2008 8:09 am
What display's the "network center" for you ?
Also check these threats:
viewtopic.php?f=16&t=192
viewtopic.php?f=16&t=273
drvolk
Postby Frits » Thu Jul 31, 2008 10:32 am
The system detects the atheros card.
But when i use the switch, only the icon appears in the screen, but nothing happens.
Also the led indicator doesn't burn any more..
So all in all, it won't work.
Cable still works fine though.
I really think it is a Linpus problem, because when i bought the One, it worked fine, but after aplying the updates with Live update, it is gone.
I did the recovery thing, but it didn't worked.
I am thinking of using another OS, like Ubuntu or Puppy Linux or something like that.
Problem is that my kids are also using the One, so the simple principle of Linpus appeals to them.
Still hoping someone knows how to fix it.
Frits
Postby tekkie » Fri Aug 01, 2008 9:08 pm
I had the same problem and got an answer from Acer to re-install from the recovery disc. Full story is here:
http://neilberman.blogspot.com/2008/08/ ... three.html
tekkie
Postby Frits » Sun Aug 03, 2008 8:39 am
i used the recovery disk, but i won't work.....i did it three times.
still can use cable, but the wireless is gone, everything.
No tray icon, no led burning. when i use the switch the on screen icon apears, that's all, nothing happens.
So, come on Linpus or Acer, fix it.
Frits
Return to Networking & WiFi
