READ ME - FOR NEW LINPUS LINUX USERS
For new user questions only, please search incase the question has been asked before.
Postby KiNG » Sun Jul 27, 2008 2:26 pm
As requested by a member on the board
Basic things you need to know using Linpus - if your a total linux beginner, read further reading below.
To activated advanced mode - goes into the real operating system of linpus, allows you add/remove programs etc..
see here - viewtopic.php?f=13&t=28
Packet Manager - add/remove software
Once the advanced mode has been activated, under System you will find Add/Remove Software which is the Red Hat/Fedora Packet Manager. You will need your password (the one you set up during installation) to access it. Now you can install programs.
Opening shell terminal - open a terminal (alt F2) on acer aspire one
http://linuxreviews.org/beginner/#toc5
Further reading
http://www.reallylinux.com/docs/windowstolinux.shtml
http://www.linux.ie/newusers/beginners-linux-guide/
Drivers Windows XP / Vista / BIOS - http://www.aspireoneuser.com/downloads/
Thx to all the members who has posted the above information, credit to them :)
www.aspireoneuser.com - Acer Aspire One Netbook Resource - www.aspireoneuser.com/forum - Acer Aspire One User Forum
www.cardrecovery.co.uk - Memory Card Recovery Service
Please show your support for the site - look here - Buy the Acer Aspire One and extra batteries / parts here
KiNG
Site Admin
Re: READ ME - FOR NEW LINPUS LINUX USERS
Postby miketurley » Sun Aug 17, 2008 3:41 pm
I have had my One for two weeks and am just coming to grips with Linux - this is my first experience! I've tried to follow the instructions to open up the advanced mode but cannot get it to work. My problem seems to be setting up 'xfce-setting-show' in the terminal.
Can anyone give me some detailed step by step instructions? This real Linux rookie will be very grateful!!
miketurley
Postby OneHead » Sun Aug 24, 2008 3:40 am
miketurley wrote:Can anyone give me some detailed step by step instructions?
Have you tried the instructions as directed above (http://www.aspireoneuser.com/forum/viewtopic.php?f=13&t=28) ?? Those are step-by-step ...
AOA110L 1GB dual-booting Linpus and NLite XP SP3
OneHead
Postby miketurley » Mon Aug 25, 2008 5:01 pm
many thanks - all OK now - I'm learning fast!
miketurley
Postby ratbag » Mon Sep 01, 2008 11:47 am
hi i am a newby i just got a acer aspire one, and i am trying to updated firefox, i do not uderstand on this form page about hack, i have manage so far as to go to my file, go to terminal, and then i am just lost what do next. please help.
ratbag
Postby Albertde » Wed Sep 03, 2008 9:56 pm
The basic problem I believe (could be wrong) with upgrading to Firefox 3 is the Aspire One plugin that was built for Firefox 2 specifically to enable users from the browser to view and listen to Windows Media and other video and audio files encountered on the web "without downloading", i.e., without having the normal Windows Media (or other) player.
Albertde
Postby chazzmor » Fri Sep 19, 2008 4:05 am
miketurley wrote:I have had my One for two weeks and am just coming to grips with Linux - this is my first experience! I've tried to follow the instructions to open up the advanced mode but cannot get it to work. My problem seems to be setting up 'xfce-setting-show' in the terminal.
This is what worked for me:
1. From the Desktop, under the Files Group, click on My Documents
2. When the Documents- File Manager window opens up, click on File, then on Terminal
3. Starting at the black cursor, type: xfce-setting-show (Don't use any quotation marks)
4. Press ENTER key.....(don't laugh, that's what held me up for 2 hours. I forgot to press Enter)
5. Another window will open with several icons.
6. Left click the Desktop icon and another window will open with 2 tabs
7. Left click the Behavior tab
8. Look down the list for the "Show desktop menu on Right click" and check(click) the box.
9. Close all windows and return to your Desktop.
10. Now, if you Right click anywhere on your desktop the Menu will open.
chazzmor
Postby cjc9280 » Sun Sep 21, 2008 3:30 pm
Hi, I'm considering buying an Acer ASpire One - 512mb, linux, but I was told it doesn't come with any pre-installed software?? only linux. I know I can download open office, but what about the messenger, skype and games?? I am very confused. How easy is it to configure / install new software??
cjc9280
Postby Grim Squeaker » Sun Sep 21, 2008 4:19 pm
The linux version includes OpenOffice, a custom made messengerprogram, mediaplayer, photoviewer and emailprogram, as well as several demogames. Skype is not included by default, but can be installed.
Since the included Linpus Linux is based on fedora 8 you can also install many programs from the fedora repositories. Some incompatibilities might occur there though.
Grim Squeaker
Postby cjc9280 » Sun Sep 21, 2008 6:55 pm
Grim Squeaker wrote:The linux version includes OpenOffice, a custom made messengerprogram, mediaplayer, photoviewer and emailprogram, as well as several demogames. Skype is not included by default, but can be installed.
Excellent, thanks. Not sure what "fedora 8" is though - am going to order my acer tomorrow - the Acer Aspire One AOA150-Ab.
cjc9280
Return to Beginners Section
