usb linpus restore disk
For new user questions only, please search incase the question has been asked before.
Postby hmmmmmmm. » Thu Nov 27, 2008 9:44 pm
i need to create a usb restore disk from the supplied dvd but i dont use pc's like the instruction specify as i use an applemac
can anyone help?
hmmmmmmm.
Re: usb linpus restore disk
Postby barrie » Fri Nov 28, 2008 12:59 am
Hi hmmmmmmm.
To create the USB recovery stick do the following.
Important Note.
Please do not undertake the following if you are using a SATA drive /drives
How to make and use a recovery for Acer Aspire One – For Linux SKU
Required materials:
- USB key from minima; 8GB
- Aspire One Recovery DVD, which is shipped with the Aspire One.
- Additional PC / notebook
Step 1
Insert the “Aspire One Recovery DVD” into the additional PC / notebook, and make sure that the device
will boot from this DVD. You might need to enter the system BIOS to enable booting from optical disc
drive.
Step 2
Once you have booted from the DVD, you can select the following 3 options:
Install – Acer Aspire One
Create Recovery USB Drive
Boot from Hard Disk
Please select the option “Create Recovery USB Drive”. After selecting this option, the system will
continue to the “Acer Recovery Management” screen.
Step 3
The “Acer Recovery Management Screen” will automatically launch a wizard which will help you with
creating the recovery USB drive.
Step 3- A Welcome
Welcome to the Acer Recovery Management for Aspire One. This program will assist you to create a
recovery USB drive. Press [->] to continue, or press [Exit] to quit.
Press the next button [->] to continue.
Step 3- B Select partition
Select USB drive and click Next button to continue
In this screen you can select your inserted USB drive, for example:
Whole disk 1 /dev/sdb 3936MB
All data on the selected partition / drive will be overwritten!
Step 3- C Recovering data
The system will now start copying data to the USB drive. You will see a progress bar on which you can
see the progress of the copying progress. This progress will take about 5 minutes.
After this take out the USB drive and insert the USB drive into the Aspire One
Step 4
When the USB drive is inserted into the Aspire One, press the power button and press F12 to enter the
boot menu. In this menu, you will see the following:
1. IDE 0: SSPAMM0008G1EA
2. USB HDD: USB Flash Drive
3. Network Boot: Legacy PCI Device
Select “USB HDD: USB Flash Drive” and press ENTER.
Step 5
The system will now boot into the “Acer Recovery Management” utility which you can use to restore the
Aspire One.
Step 5- A
Select the partition on which the software needs to be restored. By default this is the following:
Whole Disk 1 /dev/sda/ 7695MB
After selecting the partition the system will display a message that all data on the partition will be
removed. Press OK to continue
Step 5- B
As a final step the system will start to copy data from the USB drive to the SDD drive of the Aspire One.
This process will take about 20 minutes, depending of the speed of the USB drive.
After copying files, remove the USB drive and reboot the system. Remove the USB drive first!
Aspire One Linpus / XFCE desktop
barrie
Postby crazymazy » Wed Feb 18, 2009 10:26 pm
That for the info! Work! Did have to find a machine which I could create the USB recovery disk on - Third time lucky!!!
crazymazy
Postby barrie » Thu Feb 19, 2009 12:22 am
Hi crazymazy,
You are welcome, and I take it from your post all is OK, just to add to mine a friend somehow killed her new AAO so we used the USB recovery disc I created via the above instructions, it took about 25 mins but her box was restored to out of the box condition (new) and is now working well.
The only difference was I used a 8Gb stick instead of the 1Gb in the instructions. ;)
barrie
Postby redtree » Fri Feb 20, 2009 7:03 pm
You can also set up a restore USB stick which will restore your system to how you set it up. The DVD that came in the box will restore it to as new. Details of how to set it up can be found on Macles blog here:
http://macles.blogspot.com/2008/12/acer ... ackup.html
Hope it helps
redtree
Postby barrie » Thu Mar 05, 2009 8:09 am
Hi redtree,
Thank you for the link, I followed the instructions and made a system backup. The only thing not detailed was the fact that 95% through the backup process I got a blue screen and no matter what could not bring the desktop back. :o :shock:
I decided to wait a few minuets then finally hit the on/off button, bingo back to the terminal and the backup had finished. :)
Hit any key to reboot so removed the USB key and did this all was fine, replaced the USB key to check the files and all seems fine with the USB boot and backup files etc created.
I will load a few more app`s then run this recovery stick to see if it takes the system back to as I had it set up.
If this is successful then it is a great piece of software, I know it only takes 20 mins to use the rescue USB stick that I created which takes the Acer back to out of the box condition (new) which I have done, but much better if you can just restore the system to as you had it with all loaded programs and applications. ;)
We shall see.
barrie
Postby Ricardo Miguel » Tue Mar 10, 2009 4:24 pm
Hi, i did what was told here and it gives me an error that says that it canot format my 16gb usb disk, tried with a 2gb and another error to contact the linpus suport, and did not format, what can i do?
Ricardo Miguel
Postby barrie » Tue Mar 10, 2009 5:02 pm
Hi Ricardo,
Not sure I fully understand, are you saying you can not create the USB recovery stick?
Because once you enter the Acer Recovery Management the following will happen,
Overwritten is the operative word not formatted.
barrie
Postby nenu » Sat Mar 28, 2009 11:38 pm
Ok stupid question...if I put the recovery disk into another machine to create the USB stick what happens to the OP on that machine.
My home laptop runs windows Vista and I have a load of stuff on it that I don't want to risk losing. The Documents I have saved to an external hard drive, but not the programmes etc.
Please can some one reassure me :)
nenu
Postby barrie » Sat Mar 28, 2009 11:59 pm
Hi nenu,
Nothing happens to your desktop / laptop, it is only reading the disk in order to make a rescue USB stick.
No files are downloaded onto the PC. :)
I have used it to take my Acer box back to new, worked flawlessly.
barrie
Return to Beginners Section
