SlCKB0Y Kernel 2.6.29.1 Downloads - Update!
Postby SlCKB0Y » Sun Jan 11, 2009 1:33 pm
Update
Website is back online, sorry for the issues
http://www.aspireonekernel.com
Yes I believe the acerhdf isnt working with this kernel. I will recompile in the next few days.
Sorry about all the delays I have been really busy with a new job.
Custom Aspire One Kernel Debs
http://www.aspireonekernel.com/
SlCKB0Y
Re: SlCKB0Y/Kuki kernel 2.6.28 Release
Postby eruhuan » Sun Jan 11, 2009 1:51 pm
first reply, yey!!!!
great work! im one of those thats having a problem with one of my SDHCs, well i'll post if anything changes, im DL'ing now
eruhuan
Postby csmo » Sun Jan 11, 2009 1:53 pm
csmo
Postby SlCKB0Y » Sun Jan 11, 2009 1:59 pm
csmo wrote:I have a question related to this:
SlCKB0Y wrote:This kernel will also install under the Ubuntu Netbook Remix image, but since it is LPIA, you will need to install with
sudo dpkg -i --force-architecture linux-image-2.6.28_Sickboy.Kuki.0.1_i386.deb
Is this all I need to do, do I simply need to reboot after that and everything will be sweet and dandy? And will it have any effect if I'm already running the netbook remix on a ext2 file system?
Yes. It should simply be a matter of doing that and rebooting. The filesystem will be fine - The kernel supports etx2 and ext3 builtin and ext4, xfs, reiserfs etc as modules.
SlCKB0Y
Postby csmo » Sun Jan 11, 2009 2:03 pm
csmo
Postby SlCKB0Y » Sun Jan 11, 2009 2:05 pm
eruhuan wrote:first reply, yey!!!!
Dont know if this will help, but people seem to be trying this
If somebody has still problems with sdcard, the solution is debug_quirks in sdhci module.
Add this into your kernel line:
sdhci.debug_quirks=1
and everything should works now
From
http://bbs.archlinux.org/viewtopic.php?id=51796&p=31
SlCKB0Y
Postby csmo » Sun Jan 11, 2009 2:06 pm
csmo
Postby jearle » Sun Jan 11, 2009 2:44 pm
Just downloaded and applied to my almost new install of 8.10 (EasyPeasy build)
The start of the output log is:
Selecting previously deselected package linux-image-2.6.28.
(Reading database ... 90896 files and directories currently installed.)
Unpacking linux-image-2.6.28 (from linux-image-2.6.28_Sickboy.Kuki.0.1_i386.deb) ...
Done.
Setting up linux-image-2.6.28 (Sickboy.Kuki.0.1) ...
Hmm. There is a symbolic link /lib/modules/2.6.28/build
However, I can not read it: No such file or directory
Therefore, I am deleting /lib/modules/2.6.28/build
Hmm. The package shipped with a symbolic link /lib/modules/2.6.28/source
However, I can not read the target: No such file or directory
Therefore, I am deleting /lib/modules/2.6.28/source
Running depmod.
etc
etc
etc
So is this message important? Without those symbolic links working, has the update failed? The rest of the output continued ok, and I don't know what/where to check to see if the new kernel is in use.
jearle
Postby SlCKB0Y » Sun Jan 11, 2009 2:54 pm
jearle wrote:Just downloaded and applied to my almost new install of 8.10 (EasyPeasy build)
Done.
Running depmod.
etc
etc
etc
this is normal
Reboot and do a uname -r to check the kernel is being used.
SlCKB0Y
Postby csmo » Sun Jan 11, 2009 3:02 pm
csmo
