Custom desktop script (DEPRECATED)
New forum just for customizing your Acer Aspire One, desktop, wallpaper, icons, overall look, search bar.
Postby k0ro » Wed Aug 13, 2008 10:37 pm
WARNING: This script is deprecated and will NOT be updated. New kernels (>2.6.27) fully support the AOne hardware, so consider installing a standard distribution (ZenWalk, Ubuntu, Debian...). Maybe it's a little hard at first, but you'll get a clean, fully customizable and upgradeable environment (Linpus has many hacks an it's really hard to clean the mess it leaves behind).
After some days tweaking the Desktop of my new shiny Aspire One ;-), I've decided to write a script to automate the process if I ever need to restore the system with Acer's Recovery CD. I think this can be also useful for those who are tired of the boring Linpus desktop and want a fully customizable Xfce 4 environment. My script performs the following operations:
  • Replace Linpus modified Xfce4 packages with the standard ones.
  • Replace kpowersave with acpid+xfce-battery-monitor.
  • Install self-compiled kernel modules for USB Modem (including many mobile phones), PPP compression and Bluetooth.
  • Install mplayer (fully featured), vlc (default player for Thunar), claws-mail, pidgin (IM) and bluetooth utils.
  • Remove buggy gtkrc-2.0 (makes the xfce standard panel insanely big).
  • Add the /usr/bin/rem_driver.sh script to remove the WiFi driver before suspend (without this the Atheros card sometimes hangs and I need to reboot).
  • Download and install Firefox 3.0.1 (consumes less memory and has more features, what else do you want? ;-) and enable mplayer and flash-player plugins.
  • Replace mplayerplug-in with a new version (gecko-mediaplayer). Now you can watch those apple trailers fullscreen in your Aspire One! (Added: 08/14/08 19:21 GMT+1)
To use this script, you'll need to have your AC power source plugged and (reliable!) network connection. Simply download it (aone-config.sh), open a terminal (ALT+F2 and enter "xterm"), and run the script this way:
cd Downloads
sudo sh ./aone-config.sh
BEWARE: This process can't be reversed, if you want to recover Linpus Desktop (or if something goes wrong with the installation) you'll need to use your Recovery CD, probably losing all your personal data stored in the SSD.
After running the script, you should get something like this:
Linpus modded
k0ro
Re: Custom desktop script
Postby danthegoodman » Thu Aug 14, 2008 6:31 am
So... Will this hinder the battery life or increase boot-time?
Is there a way (I haven't dug too deeply into your script) to enable both the acer/kiddie desktop and the regular desktop? Kinda like linpus was supposed to support?
Will this fix issues with things like panel-customization?
Thanks for releasing this though! I'm looking forward to trying this out for myself.
danthegoodman
Postby janss » Thu Aug 14, 2008 7:38 am
Wow, this looks sweet :geek:
I just might have to try that out... The easy mode is usable, but sometimes it bugs me a bit so an easy conversion to a normal desktop might be just what I was looking for.
edit: I was just wondering what will happen on the next live update after those mods...?
tweaking better use of pearly white One - 1,5 GB / 8 GB SSD, 6 cell, Ubuntu 8.10
resident mod of hardware/linux sections
janss
Postby k0ro » Thu Aug 14, 2008 10:40 am
danthegoodman wrote:So... Will this hinder the battery life or increase boot-time?
Boot time is almost the same, and battery life shouldn't be affected, but you'll save about 80 MB of RAM (Linpus desktop uses about 280-300 MB, while this desktop only takes 200 MB).
danthegoodman wrote:Is there a way (I haven't dug too deeply into your script) to enable both the acer/kiddie desktop and the regular desktop? Kinda like linpus was supposed to support?
Nope, since Linpus' Xfce packages are replaced, you must choose between both Desktops.
danthegoodman wrote:Will this fix issues with things like panel-customization?
Sure! You can change everything you want, just as in a standard Xfce Desktop (well actually it is a standard Xfce Desktop ;-)
k0ro
Postby k0ro » Thu Aug 14, 2008 10:56 am
janss wrote:edit: I was just wondering what will happen on the next live update after those mods...?
Running Live Update after changing your desktop might give unexpected results. I mean, it should work as soon it doesn't touch Xfce packages, but since Live Update downloads custom scripts that can change almost everything in your system, I can't guarrantee that. I've just updated my system and everything went fine, I've just needed to remove again the kpowersave and scim packages that I don't need (and are a waste of memory).
My advice is, if you have changed your Desktop, and your system is working ok, just don't update. In the future, if you need an update to fix/improve something, the recover your original Desktop (by using Acer's Recovery CD), update your system and change your desktop again (I'll try to provide new versions of my script if gets broken by a future update).
k0ro
Postby bannedi » Thu Aug 14, 2008 12:56 pm
WOW! i will try it today, is easy to put icons on the desktop?
bannedi
Postby k0ro » Thu Aug 14, 2008 4:50 pm
bannedi wrote:WOW! i will try it today, is easy to put icons on the desktop?
As easy as right-click over an already existing icon (like "Home") and Desktop->Create Launcher :-)
k0ro
Postby bannedi » Thu Aug 14, 2008 6:10 pm
works perfect!! thank you
bannedi
Postby andif62 » Thu Aug 14, 2008 6:21 pm
Great!!! Tried to modify desktop for myself but only got it empty without any icon.
Works perfectly but boot time is longer
White Acer Aspire One A110L, 1.5 GB RAM, 8 GB SSD, running Linpus Linux Lite
andif62
Postby Wesi72 » Thu Aug 14, 2008 6:24 pm
Works well, thanks - only problem seems to be that I have to put my WiFi password in everytime I boot up.
Wesi72
Return to Desktop Customization
