WLAN / WIFI Card Issues
Post regarding making a new connections or questions about Home / Office Networking and WiFi
Postby techie » Mon Aug 18, 2008 3:48 am
Seems like a few of us are experiencing this issue. Unfortunately there is no one spot to centralize the issue (I've noticed messages in Hardware/Networking/Windows/Linux forums).
Please reply to this post if you are experiencing any or all of the following
Symptom
After standby or sleep, the Aspire refuses to reconnect over wireless. Only reboot or power off resolves this.
Wifi suddenly disconnects and wifi light is either off or on steady. Only reboot or power off resolves this.
Combined with either of the above, the wifi card may disappear from either device manager in XP or System info in Linpus
Perhaps if we have enough occurrences, then Acer will prioritize a fix.
How about making this a sticky item until it is resolved?
Here are some relevant posts
http://www.aspireoneuser.com/forum/viewtopic.php?f=16&t=509
http://www.aspireoneuser.com/forum/viewtopic.php?f=24&t=902
http://www.aspireoneuser.com/forum/viewtopic.php?f=24&t=1448
http://www.aspireoneuser.com/forum/viewtopic.php?f=4&t=1267
http://www.aspireoneuser.com/forum/viewtopic.php?f=16&t=1243
http://www.aspireoneuser.com/forum/viewtopic.php?f=16&t=1088
And in a bizarre coincidence...I just lost wireless posting this and had to save in a text file...geez...
techie
Re: WLAN / WIFI Card Issues
Postby midgetdiablo » Mon Aug 18, 2008 4:10 am
Hmm... I dont think I have this problem. I know Acer is known for having problems after standby/hibernate mode. Their way of fixing it is through BIOS updates, so I guess we just have to wait for the next BIOS update.
Brian Houng
Aspire One AO150-Bb (XP, 120GB, 6-cell)
midgetdiablo
Postby judeh101 » Mon Aug 18, 2008 4:12 am
how about flicking the wifi switch? will that work?
Does this only occur on the linux systems?
AOA150, 6 cell, windows 7 ultimate, Gateway LT1004u 3103 bios
ASUS P5K motherboard, 2 gigs DDR2 800 4-4-4-12 2.1V, 9500GT OC'ed, C2D E4300 3.2GHz, 160, 80 gig hdd, 8540 3DMark06
judeh101
Postby techie » Mon Aug 18, 2008 4:48 am
The switch doesnt seem to help...nor does disable/enable in windows. Seems to be in both XP and Linpus.
techie
Postby judeh101 » Mon Aug 18, 2008 6:07 am
seems like we need a new BIOS update then.
judeh101
Postby Sid » Mon Aug 18, 2008 7:22 am
Applying the custom desktop script seems to fix the loss of wifi after sleep.
have a read viewtopic.php?f=31&t=1256&st=0&sk=t&sd=a
Sid,
AOA 110-Ab, Linpus (No M$ here) 1.5 gig of ram and NO swap activity - Proud owner since 27th July 2008
PNY DDR2 PC2-4300 1Gb 533mhz SODIMM 200pin
Sid
Postby pmosher » Mon Aug 18, 2008 8:54 pm
I have the "sudden disappearance" of the WiFi card, disconnecting me from the network. I can get it back either by power off/on, or most times by just shutting the lid (to put it to sleep, I suppose), waiting a bit, and reopening. When it resumes from sleep the wireless reconnects.
I have run the "desktop customization" script referred to above for a more or less vanilla Xfce desktop, and the behaviour of the WiFi card was the same before and after doing so.
Will watch this thread for further reports and/or developments.
Pauline
Blue AAO Linux (Linpus Lite)
pmosher
Postby techie » Mon Aug 18, 2008 9:02 pm
For those of you running XP with this problem, the following message may appear in Event Viewer
PlugandPlay Error
The device 'Atheros AR5007EG Wireless Network Adapter' (PCI\VEN_168C&DEV_001C&SUBSYS_E008105B&REV_01\4&2803e7c1&0&00E2) disappeared from the system without first being prepared for removal.
techie
Postby pmosher » Mon Aug 18, 2008 9:04 pm
Considering that this disappearing WiFi card happens in both Linux and WinXP, this may be a dumb question, but does anyone know whether these symptoms occur in machines that have had Ubuntu installed?
pmosher
Postby retsaw » Mon Aug 18, 2008 11:40 pm
I have had problems with wireless sometimes not working after coming back from sleep in Linpus Linux, but this seems to be a mostly software fault since I have always been able to regain connectivity by restarting NetworkManager, usually with a simple restart using the init script "sudo /etc/init.d/NetworkManager restart", though on a couple of occasions where that wasn't working I had to execute "sudo killall -9 NetworkManager" to kill off the old NetworkManager process before I could restart it, then it would work.
retsaw
Return to Networking & WiFi
