Broadcom HD Decoder card BCM970012 or BCM70012
Video decoder card which provides Hardware Acceleration of video.
Thanks to Ashram
Drivers
http://h10025.www1.hp.com/ewfrf/wc/soft ... ct=3943766
Arcsoft Broadcom version of TotalMedia
Comfirmed working in WiFi slot of AOA150 with Arcsoft application and driver above.
Comfirmed working in Windows 7 Media Center when "Broadcom Video Decoder" is selected as the default video codec with the "Media Center Decoder Utility" (MCDU) tool by Gary Whittaker.
Comfirmed working as Video decoder for HiDef ATSC live TV using an internal Pinnacle 80e (HD Mini Stick) tuner
Installed "Direct Show Filter Mangaer", increased "Broadcom Video Decoder" merit value from "Do Not Use" to "Normal".
Installed DvbViewer Pro ($15.00) Any directshow TV program should work provided you can select Broadcom Video Decoder. (Except WatchTV, which has a pixelation breakup problem).
Selected "Broadcom Video Decoder" as Video codec.
De-selected "Use new tuning method", scan for channels.
HD live TV without dropped frames at 40% CPU.
