Touchscreen Mod
Hardware - Hacks / Mods for the Acer Aspire One
Touchscreen Mod
Postby Kenshin » Tue Jul 22, 2008 4:12 pm
Hello all
I recently saw http://jkkmobile.blogspot.com/2008/07/asus-eee-pc-900-touch-kit-now-available.html on JKKMobile, which demonstrates the installation of a touchscreen module for the ASUS EEE PC 900 series laptops. Fortunately, the display size is roughly the same as that used in the Acer Aspire One, so I will be attempting an installation of this module with the Acer Aspire.
I have ordered the part from fido-dido999 on Fleabay, and will be posting pictures of the procedure as I work on it. Has anyone else tried something like this yet?
Kenshin
Re: Touchscreen Mod
Postby rvbcrs » Tue Jul 22, 2008 9:54 pm
Kenshin wrote:Hello all
You ARE the man! I really hope it works! If it does I'm going to order mine right away!
Keep us posted!
Acer Apire One Blue
1,5Gb Memory
320Gb SATA Drive (Installed SATA Connector)
Bluetooth (Installed Mini Dongle)
3G (Installed MiniPCI-e connector & SIM adapter)
GPS (Through option GTM380)
ToDo: Touchscreen...
rvbcrs
Re: Touchscreen Mod
Postby Kenshin » Wed Jul 23, 2008 2:02 pm
Yup, hope it works. I may have to move some of the screw holes or do something a little crafty to get it to fit, but it should be good. I'll keep you all posted.
Kenshin
Re: Touchscreen Mod
Postby glibdud » Wed Jul 23, 2008 2:14 pm
Has anyone probed around to find any spots to tap into the USB yet?
glibdud
Re: Touchscreen Mod
Postby Kenshin » Wed Jul 23, 2008 3:49 pm
Luckily, the USB module on the right-hand side of the board (with the power and everything else) has four solder points directly above the board, so I was able to add solder to these points without having to resort to any strange trickery. I was unable to unscrew the bottom left-hand screw from the board, as that screw is in pretty damned tight. However, I was able to add the entry points and I'll be using that when I solder in the GPS receiver into the unit as well.
I'll be posting pictures as soon as I have confirmation that it's all working!
Kenshin
Re: Touchscreen Mod
Postby loopyoyo » Thu Jul 24, 2008 11:42 am
Kenshin wrote:Luckily, the USB module on the right-hand side of the board (with the power and everything else) has four solder points directly above the board, so I was able to add solder to these points without having to resort to any strange trickery. I was unable to unscrew the bottom left-hand screw from the board, as that screw is in pretty damned tight. However, I was able to add the entry points and I'll be using that when I solder in the GPS receiver into the unit as well.
any luck yet man?
loopyoyo
Re: Touchscreen Mod
Postby Davidcowling » Thu Jul 24, 2008 2:54 pm
props to kenshin..
its got to take some balls to undertake a challenge like that on a lovely, shiny AA1
Davidcowling
Re: Touchscreen Mod
Postby loopyoyo » Thu Jul 24, 2008 5:05 pm
yea..kenshin is a brave man indeed...actually someone would just need to have a little soldering experience to be able to pull this one off since were only considering a touch panel and not replacing the whole lcd itself....just gotta find those contact points for the usb and your all set....good luck man!
loopyoyo
Re: Touchscreen Mod
Postby bove » Sat Jul 26, 2008 1:01 am
I guess such a mod will also get rid of that ridicilous reflective layer covering the screen of the Aspire One?
bove
Re: Touchscreen Mod
Postby Darren198712 » Sun Jul 27, 2008 6:01 pm
I am using a external mouse lol I would love touch screen though that would be so cool but I am not sure how often I would use it lol I think I would use it more tho as the Acer1 mouse is not all that. any pics or updates of the touch screen Acer1
Darren198712
Return to Hardware - Hacks / Mods
