Play DIVX videos with the VLC media player
Linux OS and software
Postby Bor » Fri Jul 18, 2008 1:13 am
UPDATE JULY 2009
The instructions in my original post (see below) are no longer valid because rpm.livna.org/livna-release-8.rpm is no longer available. I didn’t notice this until I tried to reinstall my VLC player.
I found part of the solution to this problem on macles.blogspot.com. This blog gives the following instructions for installing the VLC player.
To install VLC just add both repositories and use yum.
wget http://download1.rpmfusion.org/free/fed ... noarch.rpm
[point with your mouse to this address to see the complete url]
wget http://rpms.kwizart.net/kwizart-release-8.rpm
sudo rpm -U *release*rpm
sudo yum install --enablerepo=kwizart-testing vlc mozilla-vlc
I opened a terminal and entered the lines above. A lot was installed, but I was informed that some dependencies were missing. However, I was able to solve this problem by entering this line:
sudo yum install fedora-release
Next I repeated the installation of the VLC player:
That solved my problem. Now everything is working fine.
OLD INSTRUCTIONS
The MPlayer that is installed on the Aspire One does not play divx videos. Fortunately, there is a simple solution. Open a Terminal and enter the following lines (including the URL):
#> su -
#> rpm -ivh http://rpm.livna.org/livna-release-8.rpm
#> yum install vlc
Answer Y(es) when asked.
This will automatically install the VLC media player for Fedora 8, that enables you to watch divx videos.
(To open a Terminal go to Files > My Documents and open the File Manager. Then go to File > Terminal. If you already did the Hack to enable the advanced desktop mode, you can right click on your desktop and select the Terminal.)
I don’t know anything about Linux, but I found this solution on a French website:
http://www.mobifrance.com/articles/eboo ... hp?id=1000
Bor
Re: Play DIVX videos with the VLC media player
Postby 2manydjs » Fri Jul 18, 2008 2:43 am
Thanks for the hint! If you want to add this to your desktop tray, link to /usr/share/applications/livna-vlc.desktop .
Acer ZG5, Moblin, 1 GB RAM Pictures and Blog
2manydjs
Postby Zadingo » Fri Jul 18, 2008 3:48 am
Your instructions were complete and easy to follow. This is the kind of useful post that I look forward to seeing more of in this forum. Thank you very much!
Zadingo
Postby Kev50027 » Fri Jul 18, 2008 6:42 am
That was very helpful for a Linux newbie, now could you help me install Pidgin? I keep getting an error saying I'm missing libpurple when typing yum install pidgin.
Thanks!
-Kev-
Kev50027
Postby oncledams » Sun Jul 20, 2008 9:41 am
To use vlc plugin in firefox for some websites, it's better to use this:
su -
yum install vlc
yum install python-vlc mozilla-vlc
works fine
oncledams
Postby pattyadams » Sun Jul 20, 2008 12:36 pm
oncledams wrote:To use vlc plugin in firefox for some websites, it's better to use this:
su -
yum install vlc
works fine
Hi I've done this but when I double click on the vlc icon on my desktop I get a message saying 'Unable to open %U"'
I can ignore the message, close the box and still use vlc but it's annoying me. I know I have to edit my vlc desktop config file but keep getting denied permission when attempting to open it in root. If anyone can help (in simple terms... I'm new to Linux) I'd really appreciate it.
Umm it's OK, I worked it out, was trying to edit the file directly instead of using mousepad!
pattyadams
Postby downdown » Mon Jul 21, 2008 3:45 am
im getting this error message please help
Error: Missing Dependency: libpulse.so.0(PULSE_0) is needed by package vlc
Error: Missing Dependency: libopendaap.so.0 is needed by package vlc-core
Error: Missing Dependency: libdvdnav.so.4 is needed by package vlc-core
downdown
Postby vzmr82 » Tue Jul 22, 2008 11:54 pm
Bor wrote:The MPlayer that is installed on the Aspire One does not play divx videos. Fortunately, there is a simple solution. Open a Terminal and enter the following lines (including the URL):
#> su -
#> yum install vlc
This worked fine, I have VLC running on my AcerOne. But I having problems with VLC dropping subtitles. Every other subtitle, it is not showing it. Sound and Video appears ok.
Any ideas?
Thnks. RS.
vzmr82
Postby oxerife » Wed Jul 23, 2008 12:11 am
vzmr82,
Go to Preferences -> Input / Codecs -> Other codecs -> Subtitles, and set Subtitle text encoding to the right one.
I selected iso-8859-1 and its working.
oxerife
Postby vzmr82 » Wed Jul 23, 2008 12:48 am
oxerife wrote:vzmr82,
Thanks, that's it. Working! (Strange, I don't have to do this in Windows or in Mac)....
vzmr82
Return to Software - Linux
