How do I put an icon for vlc media on my basic desktop?
Linux OS and software
Postby pattyadams » Fri Jul 18, 2008 8:46 am
Hi
I am new to linux but have switched on advanced mode and have downloaded and installed vlc media player. I can find it in my advanced desktop but wondered if there was any way of putting an icon onto my basic desktop? If anyone can help please keep it simple! :shock:
pattyadams
Re: How do I put an icon for vlc media on my basic desktop?
Postby dalepearson » Fri Jul 18, 2008 10:42 am
I have not yet installed VLC yet what package version did you use?
As for adding it to the desktop, location its installed location, probably be in /usr/share/applications/
Then open /home/user/.config/xfce4/desktop/group-app.xml and add the appropriate line, probably something similar to below
<app sequence="10">/usr/share/applications/vlc.desktop</app>
This should then appear in the appropriate section, then you can drag and drop it into the appropriate order.
BTW you will have to reboot before it appears.
Hope it helps.
dalepearson
Postby pattyadams » Fri Jul 18, 2008 10:51 am
Thanks will give it a go.
I used the fedora 8 package. I think I googled vlc for Fedora 8 download and went to this site:
www.videolan.org/vlc/download-fedora.html
and followed the instructions under Fedora 8
pattyadams
Postby pattyadams » Fri Jul 18, 2008 11:23 am
dalepearson wrote:I have not yet installed VLC yet what package version did you use?
Hope it helps.
I've found the desktop xml file I need to edit and I've found the usr/share/applications file for vlc but can't seem to find the appropriate app sequence.... if anybody has any ideas or knows the sequence it would be much appreciated. :)
pattyadams
Postby dalepearson » Fri Jul 18, 2008 11:38 am
Should be straight forward.
If no one has done it, I will install it when I get home and let you know, unless I can get on a network here later.
dalepearson
Postby pattyadams » Fri Jul 18, 2008 12:23 pm
Thanks. I'm having trouble opening the /usr/share/applications folder as it keeps telling me that nautilus file manager is not running!
pattyadams
Postby dalepearson » Fri Jul 18, 2008 4:37 pm
OK I have added this to my fun section.
<app sequence="6">/usr/share/applications/livna-vlc.desktop</app>
Then drag and drop where appropriate.
dalepearson
Postby skateasian » Fri Jul 18, 2008 8:51 pm
i cant even access home. it doesnt let me. how do i get to that file?
skateasian
Postby dalepearson » Fri Jul 18, 2008 9:29 pm
Go to the file manager, then where it says "My Disk:///" just paste in /home/user/.config/xfce4/desktop/group-app.xml
dalepearson
Postby shinratdr » Fri Jul 18, 2008 11:28 pm
I don't know how you got your version of VLC, but I got mine from the linva repository. so xml needed to say "linva-vlc.desktop". Also the command somehow got garbled when I downloaded it, so I had to edit the desktop config file in root to remove the " &U" that got added to the end of the VLC command, or else clicking the icon would launch vlc but give me an error. Hope some of this helps.
shinratdr
Return to Software - Linux
