Backtrack BT3 screen resolution
Linux OS and software
Postby Grinder » Mon Aug 25, 2008 10:00 pm
I've been able to get BT3 to boot into KDE VESA mode which gives me 800 x 600 all the other boot options don't give me xwindows. Has anyone been able to get a 1024 x 600 resolution in Backtrack? At least I'm getting the 800 x 600 which is a step above the 800 x 640 from my EEE PC.....
Grinder
Re: Backtrack BT3 screen resolution
Postby vexer » Thu Oct 23, 2008 3:37 am
I haven't been able to get BT3 to work in anything other than 800x600. Most if not all the xorg.conf files i've checked out use the intel driver for video. I've tested changing the driver setting to intel but end up with an error:
(WW) intel: No matching Device section for instance (BusID PCI:0:2:0) found.
Which I then add in the line BusID PCI:0:2:0 to my xorg.conf file which leads to a second message, the same as above except for "[...] (BusID PCI:0:2:1) found." Instead of 0:2:0
vexer
Postby cheops » Thu Oct 23, 2008 8:22 pm
This is a question I'd dearly like to see answered!
surely it must be possible to run BT3 at 1024x600....
I'm darned if I can figure it out though :?:
cheops
Re: Backtrack BT3 screen resolution - SOLVED
Postby cheops » Sun Oct 26, 2008 4:38 pm
You need a copy of the correct video driver module.
You can get it from:
http://rs237.rapidshare.com/files/138927294/901_net_gfx.lzm
Put it into the following folder:
/BT3/Optional
Now you need to edit the following file:
/boot/syslinux/syslinux.cfg
Add in the following text AFTER the first three lines:
LABEL aa1
MENU LABEL BT3 Acer Aspire One Mode
KERNEL /boot/vmlinuz
APPEND vga=785 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw changes=/changes/slaxsave.dat load=901_net_gfx  autoexec=kdm
so the file now looks like:
PROMPT 0
TIMEOUT 40
DEFAULT /boot/vesamenu.c32
LABEL aa1
LABEL cubez
MENU LABEL BT3 Graphics mode (Compiz) - Experimental
APPEND vga=0x317 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw chexpand=256 load=cubez autoexec=xconf;cubez;startx
LABEL cubez
MENU LABEL BT3 Graphics mode (Compiz Nvidia) - Experimental
APPEND vga=0x317 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw chexpand=256 load=cubez,nvidiadriver autoexec=xconf;startnvidia.sh;startx
LABEL xconf1
MENU LABEL BT3 Graphics mode (KDE)
APPEND vga=0x317  initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;kdm
LABEL xconf2
MENU LABEL BT3 Graphics mode (Flux)
APPEND vga=0x317  initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;flux
LABEL startx
MENU LABEL BT3 Graphics mode (VESA KDE)
APPEND vga=0x317 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw autoexec=kdm
LABEL BT3
MENU LABEL BT3 Text mode Frame Buffer
LABEL BT3_no_DHCP
MENU LABEL Run BT3 no DHCP
APPEND vga=0x317 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw nodhcp
LABEL BT3_no_HD
MENU LABEL Run BT3 no Hard Disk
APPEND vga=0x317 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw nohd
LABEL BT3_Safe
MENU LABEL Run BT3 Safe Mode
APPEND vga=normal initrd=/boot/initrd.gz ramdisk_size=6666
root=/dev/ram0 rw
LABEL pchanges
MENU LABEL BT3 Graphics mode with Persistent Changes
APPEND vga=0x317 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw changes=/changes/slaxsave.dat autoexec=xconf;kdm
LABEL copy2ram
MENU LABEL BT3 Graphics mode, Copy To RAM
APPEND vga=0x317 initrd=/boot/initrd.gz ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=xconf;kdm
LABEL msramdmp
MENU LABEL msramdmp
com32 /boot/msramdmp.c32
LABEL memtest86
MENU LABEL Run Memtest utility
KERNEL /boot/mt86p
Reboot into backtrack and select [BT3 Acer Aspire One Mode] and it should boot into KDE at 1024x600
cheops
Postby rbil » Sun Oct 26, 2008 7:03 pm
Thanks so much cheops. That is really nice to have.
Cheers.
Create a Backup/Restore Solution on a Flash Key...
Need help with chmod? Use the CHMOD Calculator on the site.
rbil
Postby BlackSolidus » Mon Oct 27, 2008 11:39 pm
:o Thank u very much Cheops i was looking for that answer for about 5 days, its works perfectly. :)
BlackSolidus
Postby dirk » Tue Oct 28, 2008 9:12 am
Working great here also, thanks for the info.
dirk
Postby cheops » Tue Oct 28, 2008 10:40 am
you're welcome :)
cheops
Postby hobojoe196061 » Wed Nov 19, 2008 9:33 pm
im new to linux so i need a little help...how do u you edit the fie? do i edit it while in linux or can i do it from windows?
thanks
hobojoe196061
Postby rbil » Thu Nov 20, 2008 3:22 am
I'd use a Linux text editor, like mousepad, because Windows editors write end of line characters differently than Linux editors.
Cheers.
rbil
Return to Software - Linux
