SSD unbearably slow under XP
Windows OS and software
Moderators: Ranjit, rory
Postby techie » Thu Jul 10, 2008 8:16 pm
I installed XP and found the SSD speed to be unbearable. Far slower than my ASUS 701. Any ideas why? Re-installed the Linspire stuff in the meantime...
I used the Acer Chipset driver but that didnt seem to help.
techie
Re: SSD unbearably slow under XP
Postby nizmo » Thu Jul 10, 2008 8:23 pm
Hmmm,
I still am in two minds whether I should go for the SSD version or not...
Now that you saying this, its made it even harder to choose !
nizmo
Postby KiNG » Thu Jul 10, 2008 8:34 pm
Did you try disabling the pre-feteching in windows xp ?
Are you using 512mb ram or more ?
www.aspireoneuser.com - Acer Aspire One Netbook Resource - www.aspireoneuser.com/forum - Acer Aspire One User Forum
www.cardrecovery.co.uk - Memory Card Recovery Service
Please show your support for the site - look here - Buy the Acer Aspire One and extra batteries / parts here
KiNG
Site Admin
Postby techie » Thu Jul 10, 2008 8:42 pm
I have reverted back and don't have any issues under Linspire. I didnt change any settings (DMA, pre-fetch etc). And have the base 512 meg of RAM.
techie
Postby rscutaru » Thu Jul 10, 2008 8:43 pm
I also uninstalled Windows. What helped a lot was to set up my page file, on a SD card, I also created a ram drive Z: to store my temp internet files. Besides that there is not much you can do but disabling prefetch as King said. I have a 30GB 1.8" HDD zif 44 coming in form some country in Asia and I will replace my SSD.
rscutaru
Postby KiNG » Thu Jul 10, 2008 9:03 pm
forgot to add, i would only disable pre-fetching, if you have 1.5gb or 2gb of system ram, as it will crawl otherwise.
KiNG
Site Admin
Postby Duke » Thu Jul 10, 2008 9:08 pm
Still slow under Linux?
Duke
Postby techie » Thu Jul 10, 2008 10:16 pm
Not slow under Linux at all really....am using it now and its fine.
techie
Postby Duke » Thu Jul 10, 2008 10:19 pm
techie wrote:Not slow under Linux at all really....am using it now and its fine.
Excellent!
Duke
Postby Flaterik » Fri Jul 11, 2008 7:52 am
Under Linux is more and more and more and more fast than windows.
Also with only 512 mb.
Flaterik
Return to Software - Windows
