Project - SSD Mods
Hardware - Hacks / Mods for the Acer Aspire One
Project - SSD Mods
Postby Ariel » Sat Jul 12, 2008 10:51 am
ok folks looks like a few of us have managed to take apart their one and upgraded the ram. There seems to be quite a bit of space left so maybe someone could figure out if it would be possible to install one of those new samsungssds .. or some other kind of HDD??
Comments?
Ariel
Re: Project - SSD Mods
Postby zk2008 » Sat Jul 12, 2008 8:22 pm
Some members of this forum seem to suggested that the SSD in the One is removable, but to my knowledge, nobody has done it (confirmed it for certain) yet. Also, if it is removable, how is the new SSD going to attach/secure based on the differences between the old SSD and the new? I'm also curious about the HDD versions of the One... I wonder if they also use the ZIF connector? SATA? I haven't taken my One apart, or even received it yet for that matter, so keep this in mind when you read my analysis.... I'll try to respond to your question based on what I know.
The technical issues with this mod...
The current SSD is connected using a ZIF connector, it's logical that your new hardware would need to use the ZIF connector. Also, the version w/ the 2 1/2" HDD is supposed to be of slightly different dimension --bigger in some way-- which would imply that a 2 1/2" HDD or SSD won't fit in the SSD version Aspire One chasis... so you'd be limited to the 1.8" HDD or SSD...
Together, these restrictions leave you with the option of any 1.8" SSD using ZIF a connector or 1.8" HDD using ZIF a connector.
My concern (other than the high price/benefit ratio) with buying an 1.8" SSD that uses ZIF is that the ZIF connector limits its interchangeability... also, I couldn't imagine there is a huge market to resell this kind of product.
My concern with buying a 1.8" HDD is that they're 4200RPM (from what I've seen online) which means you'd be sacrificing all the benefits that come with the SSD only to switch to a low-performing HDD... again what's the price/benefit?
I was considering that I might want to do this modification because some people told me they installed Windows on their Linux version and the SSD was SUPER slow... I was worried that the SSD was just slow in general and that I was going to want to upgrade the SSD... but then someone explained that I'd be fine as long as I'm running Linux (which is what I want the system for)
So this is my recommendation:
If you haven't yet purchased your One yet, you should choose the One that fits you best...
If you want to run Linux only, purchase the 512MB 8GB SSD Linux version.
If you want to run Windows, or multiple OS, on your One and you haven't purchased it yet-- get the HDD version...
If you've already purchased your One, do whatever makes sense to you.... but for me, the ZIF connector ruins everything and upgrading from the SSD is probably the last thing I'll do...
Good Luck!
zk2008
Postby andy53 » Mon Jul 14, 2008 10:29 am
I ready install Transcend 8GB 300x CF to replace the int. SSD, it run cold start windows xp pro SP3 (standard install - not slim) at 20 second and shutdown at 14 second. :lol: :lol:
andy53
Postby Ariel » Mon Jul 14, 2008 11:36 am
cool! can you please post pictures when you install ?
Ariel
Postby grabejud » Mon Jul 14, 2008 12:37 pm
andy53 wrote:I ready install Transcend 8GB 300x CF to replace the int. SSD, it run cold start windows xp pro SP3 (strandred install - no slim) at 20 second and shutdown at 14 second. :lol: :lol:
now this is a good one, post some pics bro..
A1 mods and accessories:
converted my ssd to zif hdd
OSX mod
ac ryan ext. battery
grabejud
Postby andy53 » Mon Jul 14, 2008 1:34 pm
Sorry To All
My mod SSD to CF300x is base on who ready get acer one, and hopefull install Windows OS with normal performance,
Not for user , plan to buy a brand new with this mod, waste time and money.... :cry: :cry:
andy53
Postby loopyoyo » Mon Jul 14, 2008 2:00 pm
image post didnt work...can ya try again..maybe external link to flickr or something
loopyoyo
Postby andy53 » Mon Jul 14, 2008 2:09 pm
I ready install Transcend 8GB 300x CF to replace the int. SSD, it run cold start windows xp pro SP3 (standard install - not slim) at 20 second and shutdown at 14 second. :roll: :lol: Read speed 44MB/s Write 22MB/s
Image Image
Image Image
Image Image
andy53
Postby loopyoyo » Mon Jul 14, 2008 2:13 pm
still no luck man...maybe try imageshack or flick and put the individual links in
loopyoyo
Postby rscutaru » Mon Jul 14, 2008 3:33 pm
Thats awesome I ordered one of those from fleabay.
rscutaru
Return to Hardware - Hacks / Mods
