Extending your desktop onto an external monitor
Postby brentashley » Tue Jul 15, 2008 4:07 am
Here is how I have my One set up with an external monitor.
Be extremely careful editing your xorg.conf file, you can really bugger things up. You have been warned, and I won't be helping you fix it.
I have a 1280x1024 17" external LCD plugged into the Aspire One.
When I boot up, the display comes up on both the builtin LCD display and the external monitor, both at 1024x600. Yechh.
Once booted up, get into the terminal. You can use the My Documents app in the Files section, and choose File...Terminal from the menu.
Edit your xorg.conf file:
sudo mousepad /etc/X11/xorg.conf
right near the bottom in the "Screen" section there is a line that says
Virtual 1024 600
change it to say
Virtual 2304 1024
also, I added the resolutions "1280x1024" and "1024x768" to the Modes line right above the Virtual line.
This will make sure the virtual screen space is big enough to accomodate a 1280x1024 screen *beside* a 1024x600 screen.
Save and exit mousepad, then reboot to get the activate virtual screen size.
It will come up as before, but this time, open a terminal and enter the following:
xrandr -s 1280x1024
xrandr --output LVDS --right-of VGA --auto
of course, if you want your One to the left of the external monitor, use --left-of instead.
You should now be able to drag open programs between your displays.
To change your background to be less confusing, use xfce-setting-show from the terminal, select Desktop and either choose a different background, or uncheck "show image" and change Color Style to Solid Color.
- Brent -
brentashley
Re: Extending your desktop onto an external monitor
Postby Davidcowling » Tue Jul 22, 2008 4:22 pm
Excellent!
Davidcowling
Postby Sid » Fri Aug 01, 2008 10:06 pm
Thanks, very helpful. The next question is how do I make the settings permanent, so I do not have to type the commands into terminal every time?
Sid,
AOA 110-Ab, Linpus (No M$ here) 1.5 gig of ram and NO swap activity - Proud owner since 27th July 2008
PNY DDR2 PC2-4300 1Gb 533mhz SODIMM 200pin
Sid
Postby madisonman » Sat Aug 02, 2008 7:16 pm
Sid wrote:Thanks, very helpful. The next question is how do I make the settings permanent, so I do not have to type the commands into terminal every time?
Yes. anyone figure this out?
madisonman
Postby eek » Sun Aug 10, 2008 6:39 pm
i get a "connection refused" message after entering the "sudo mousepad..." command. Could you please help?
eek
Postby Sid » Sun Aug 10, 2008 6:59 pm
A "normal error" !!
Sid,
Sid
Postby Altermac » Thu Aug 14, 2008 3:19 pm
What has to be done to mirror the lcd to external VGA? It should do something like that:
virtual 1024x768 (or 1280x1024)
Internal LCD with 1024x600
external VGA with 1024x768 (or 1280x1024) same-as internal LCD
Can someone please post a working xconf.org?
Altermac
Postby DiSK » Sat Aug 16, 2008 8:15 pm
Yeah, how would you mirror the AspireOne's display onto an external monitor?
Netbook: Blue AspireOne AOA150-1249/ZG5 - 120GB
Desktop: Pentium D 950 @ 3.4 GHz, Gigabyte EP35-DS3R, 250GB HDD, 2GB RAM, Quadro NVS 290
DiSK
Postby -XoF- » Sun Aug 17, 2008 4:06 pm
This is how my external 1680x1050 works in clone mode:
- Add a new "monitor" section to xorg.conf
- adjust "virtual" settings
Furthermore, I adjusted some behaviors (e.g. CTRL-ALT-Fx switches to console)
xorg.conf:
# Xorg configuration created by system-config-display
Section "ServerFlags"
        Option "DontZap" "no"
        Option "DontVTSwitch" "no"
EndSection
Section "ServerLayout"
        Identifier     "Default Layout"
        Screen      0  "Screen0" 0 0
        InputDevice    "Mouse0" "CorePointer"
        InputDevice    "Synaptics Mouse" "AlwaysCore"
        InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "InputDevice"
        Identifier  "Keyboard0"
        Driver      "kbd"
        Option      "XkbModel" "pc105"
        Option      "XkbLayout" "de,gb,us(euro)"
        Option      "XkbOptions" "grp:alt_shift_toggle"
EndSection
        Identifier "Synaptics Mouse"
        Driver     "synaptics"
        Option     "Device" "/dev/psaux"
        Option     "Protocol" "auto-dev"
        Option     "LeftEdge"  "1700"
        Option  "RightEdge"     "5300"
        Option  "TopEdge"       "1700"
        Option  "BottomEdge"    "4200"
        Option  "FingerLow"     "25"
        Option  "FingerHigh"    "30"
        Option  "MaxTapTime"    "180"
        Option  "MaxTapMove"    "220"
        Option  "VertScrollDelta" "100"
        Option  "MinSpeed"      "0.09"
        Option  "MaxSpeed"      "0.18"
        Option  "AccelFactor"   "0.0015"
        Option  "SHMConfig"     "on"
EndSection
        Identifier  "Mouse0"
        Driver      "mouse"
        Option      "Protocol" "IMPS/2"
        Option      "Device" "/dev/input/mice"
        Option      "ZAxisMapping" "4 5"
        Option      "Emulate3Buttons" "no"
EndSection
Section "Monitor"
        Identifier  "Monitor0"
        Modeline  "1024x600" 48.96 1024 1064 1168 1312 600 601 604 622 -HSync +V
Sync
#       Option  "Above" "Monitor1"
EndSection
### This is the monitor section for an external VGA with DPMS (auto modeline selection)
Section "Monitor"
        Identifier  "Monitor1"
        Option  "DPMS"
EndSection
Section "Device"
        Identifier  "Videocard0"
        Driver      "intel"
        Option      "monitor-LVDS" "Monitor0"
        Option      "monitor-VGA" "Monitor1"
## You don't need clone mode here - cloning will be handled via xrandr
#       Option      "Clone" "true"
## Operate external VGA and internal LVDS on two seperate Pipelines
## If you want to operate both on the same Pipeline, just try "LVDS+VGA,NONE"
        Option  "MonitorLayout" "LVDS,VGA"
        BusID   "PCI:0:2:0"
#       Screen  0
EndSection
Section "Screen"
        Identifier "Screen0"
        Device     "Videocard0"
        Monitor     "Monitor0"
        DefaultDepth     24
        SubSection "Display"
                Viewport   0 0
                Depth     24
                Modes    "1024x600" "800x600" "640x480"
# set virtual to the resolution of the external VGA if you want to use clone mode
# if you want to have Xinerama-like setup, use "2704x1050" (extW+intW x extH)
                Virtual 1680 1050
        EndSubSection
EndSection
With the newest live-update (only install, if you haven't done any mods yet!) I can smoothly switch between internal and external Display using the Fn-F5 combination.
The only disadvantage is, that when using both outputs in clone mode, you'll only see a subpart of the whole screen on the internal display - scrolling is not possible.
HTH,
-XoF-
-XoF-
Postby namaste » Sun Aug 17, 2008 8:27 pm
-XoF- wrote:This is how my external 1680x1050 works in clone mode:
xorg.conf:
EndSection
EndSection
        Driver      "kbd"
EndSection
        Driver     "synaptics"
EndSection
        Identifier  "Mouse0"
        Driver      "mouse"
EndSection
Section "Monitor"
Sync
EndSection
Section "Monitor"
        Option  "DPMS"
EndSection
Section "Device"
        Driver      "intel"
        BusID   "PCI:0:2:0"
#       Screen  0
EndSection
Section "Screen"
        Device     "Videocard0"
        Monitor     "Monitor0"
        DefaultDepth     24
                Viewport   0 0
                Depth     24
                Virtual 1680 1050
        EndSubSection
EndSection
Thank you very much, so what I have to do is only to use your xorg.conf? I have a 1280x1024 external monitor crt , so the only change is Virtual 1280x1024 instead of 1680x1050 ?
HTH,
-XoF-
namaste
