INSTALL WINDOWS 7,XP,VISTA THE EASY WAY FROM USB FLASH DRIVE
Upcoming Windows 7
Moderators: Ranjit, rory
Postby soundworkspr » Sat Apr 18, 2009 12:27 pm
OK... first of my english is not that good so im going to explain this as simple as possible..
first of download the trial version of Ultra ISO found here (( http://www.ezbsystems.com/ultraiso ))
Then after u install this program open it... click on open look for your windows XP,Vista or 7 ISO file (depending on the size of the ISO file is the size on the USB flash drive u should get windows XP works on a 1GB, Vista should be on a 8 GB and windows 7 fits on a 4 GB...
After you have open the iso in the program just click on the top where it says bootable,
choose the one that says ((write image))
then a pop out window should appear choose your USB flash drive remember it should be empty if anything is on it, it will get erased.. check mark on the verify after writing..
this should take like 15 minutes an then your set to boot up from the USB
hope this is better then more complicated version... work for me
soundworkspr
Re: INSTALL WINDOWS 7,XP,VISTA THE EASY WAY FROM USB FLASH DRIVE
Postby sgladman » Sat Apr 18, 2009 4:40 pm
I installed by USB and worked fine, had to update some drivers but all ok.
sgladman
Postby soundworkspr » Sun Apr 19, 2009 12:59 am
sgladman wrote:Hi,
good to know... it worked for you.. :D
soundworkspr
Postby azz2811 » Wed Apr 29, 2009 10:32 pm
i might have to give this a try soon :)
looks very simple
Acer Aspire One, 160gb HDD, 1Gb RAM, Sexy Blue.
Windows xp dual-booted with Windows Vista Ultimate!!!
azz2811
Postby zed » Sat May 02, 2009 9:14 pm
This worked great! Very straight-forward, thanks.
Just wondering, will this same method work with installing XP?
zed
Postby tankster » Sat May 02, 2009 10:40 pm
if you have winrar installed, use it to open iso, then copy files over to usb thumbdrive.
tankster
Postby jsansom » Mon May 04, 2009 6:43 pm
Hi i followed the instructions but when trying to boot from the usb on my aspire a150 im getting the error message
INF file setup.sif is currupt or missing. status 18. setup cannot continue. press any key to exit.
Any one help me please?
Regards
J
jsansom
Postby bigsee » Wed May 06, 2009 9:31 am
Hi! It looks like a very simply mode, but i was unsuccesful. The UltraISO couldn't format the drive, on the half it stopped by an error. Is this the failure of the pendrive, or any other had the same problem?
AA1:160Gib HDD - 1Gib RAM - I Atom 1.6 - blue - W7
Desktop: MA790FX-DS5 - Athlon II X2 250 - 4 Gib RAM - 320+1000 Gib HDD - Nv8800GTS 640 - FuSi 22 - W7/HomePrem
bigsee
Postby soundworkspr » Wed May 06, 2009 2:16 pm
jsansom wrote:Hi i followed the instructions but when trying to boot from the usb on my aspire a150 im getting the error message
Regards
J
sorry for taking so long to reply.. but my father died on april,27
i have tried this with vista and windows 7 with great results.. let me know what copy of windows u r trying to put on the pen drive
And u would have to check if that copy of windows does not have any errors it could be the the ISO file is corrupted
soundworkspr
Postby soundworkspr » Wed May 06, 2009 2:18 pm
bigsee wrote:Hi! It looks like a very simply mode, but i was unsuccesful. The UltraISO couldn't format the drive, on the half it stopped by an error. Is this the failure of the pendrive, or any other had the same problem?
if your trying to put windows 7 u need a 4 gig pen drive. I never encountered this problem..
soundworkspr
Return to Windows 7
Users browsing this forum: No registered users and 3 guests
