setfsb for 11.6" and other stuff.
This forum is only for the latest 11.6" Acer Aspire One netbooks including the AMD model which is soon to be released. With so many different models out, it’s advisable to state which model you are referring to in your post.
Moderators: Davidcowling, DiSK
Re: setfsb for 11.6" and other stuff.
Postby hamsterhead » Sat May 23, 2009 4:32 pm
haha, no Fbx, I'm making typos. That was supposed to say 25,000
hamsterhead
Postby fbx » Sat May 23, 2009 11:44 pm
Well I wondered about that. So now we have the 751 performing pretty much just as the ASUS 1000HE? That makes it (751) a lot more attractive.
CrystalMark 2004R3 [0.9.126.452] (C) 2001-2008 hiyohiyo
Crystal Dew World [ http://crystalmark.info/ ]
CrystalMark 24294
ALU 5082
Fibonacci 1382
Napierian 915
Eratosthenes 1142
QuickSort 1621
FPU 3768
MikoFPU 361
RandMeanSS 1461
FFT 1139
Mandelbrot 785
MEM 4657
Read 1947.13 MB/s (1947)
Write 1137.47 MB/s (1137)
Read/Write 1139.57 MB/s (1139)
Cache 4129.58 MB/s (412)
HDD 7350
Read 53.91 MB/s (2156)
Write 53.37 MB/s (2134)
RandomRead512K 24.11 MB/s (964)
RandomWrite512K 33.63 MB/s (1345)
RandomRead 64K 5.49 MB/s (219)
RandomWrite 64K 13.32 MB/s (532)
GDI 2118
Text 990
Square 140
Circle 516
BitBlt 472
D2D 967
Sprite 10 303.41 FPS (30)
Sprite 100 142.88 FPS (142)
Sprite 500 38.04 FPS (190)
Sprite 1000 17.86 FPS (178)
Sprite 5000 4.22 FPS (211)
Sprite 10000 2.16 FPS (216)
OGL 352
Scene 1 336
Lines (x1000) (28473)
Scene 2 CPU (8)
Scene 2 Score 16
Polygons (x1000) (123)
Scene 2 CPU (1)
fbx
Postby P-Boss » Sat May 23, 2009 11:56 pm
hamsterhead wrote:well, SETFSB is compatible. I could get it to about 1.45ghz that I think is pretty stable, but haven't run an all night stress test or anything yet.
CrystalMark2004R3 up to about 2500 now, and Super PI down from 2:01 to a now 1:42. Video performance is a bit better, but nothing that was unwatchable before has become watchable...just...less bad. :P I think it's performing pretty closely to my atom N270/GMA950 systems now, as far as everyday tasks.
well i tried to use setfsb but i didn't find the right clock generator to move the fsb
Can you post me the one you used for?
Many thanks
P-Boss
Postby hamsterhead » Sun May 24, 2009 2:07 am
ICS9LPRS365BGLF
hamsterhead
Postby hamsterhead » Sun May 24, 2009 2:37 am
Clocked at default 1.24ghz
CrystalMark : 21657
[ ALU ] 4208
Fibonacci : 1431
Napierian : 673
Eratosthenes : 859
QuickSort : 1223
[ FPU ] 3585
MikoFPU : 459
RandMeanSS : 1668
FFT : 851
Mandelbrot : 585
[ MEM ] 3641
Read : 1464.69 MB/s ( 1464)
Write : 925.27 MB/s ( 925)
Read/Write : 922.01 MB/s ( 922)
Cache : 3080.35 MB/s ( 308)
[ HDD ] 7256
Read : 65.47 MB/s ( 2618)
Write : 39.55 MB/s ( 1582)
RandomRead512K : 25.19 MB/s ( 1007)
RandomWrite512K : 33.84 MB/s ( 1353)
RandomRead 64K : 4.81 MB/s ( 192)
RandomWrite 64K : 12.60 MB/s ( 504)
[ GDI ] 1881
Text : 194
Square : 326
Circle : 913
BitBlt : 448
[ D2D ] 842
Sprite 10 : 91.61 FPS ( 9)
Sprite 100 : 68.06 FPS ( 68)
Sprite 500 : 29.08 FPS ( 145)
Sprite 1000 : 17.95 FPS ( 179)
Sprite 5000 : 4.35 FPS ( 217)
Sprite 10000 : 2.24 FPS ( 224)
[ OGL ] 244
Scene 1 Score : 236
Lines (x1000) : ( 15093)
Scene 1 CPUs : ( 4)
Scene 2 Score : 8
Polygons(x1000) : ( 77)
Scene 2 CPUs : ( 1)
Setfsb at a speed of 1.45ghz
CrystalMark : 24421
[ ALU ] 5006
Fibonacci : 1768
Napierian : 787
Eratosthenes : 1003
QuickSort : 1426
[ FPU ] 4270
MikoFPU : 614
RandMeanSS : 1954
FFT : 996
Mandelbrot : 684
[ MEM ] 4291
Read : 1717.81 MB/s ( 1717)
Write : 1097.45 MB/s ( 1097)
Read/Write : 1095.52 MB/s ( 1095)
Cache : 3607.39 MB/s ( 360)
[ HDD ] 7385
Read : 62.03 MB/s ( 2481)
Write : 45.32 MB/s ( 1812)
RandomRead512K : 25.29 MB/s ( 1011)
RandomWrite512K : 34.30 MB/s ( 1372)
RandomRead 64K : 4.82 MB/s ( 192)
RandomWrite 64K : 12.94 MB/s ( 517)
[ GDI ] 2192
Text : 229
Square : 380
Circle : 1072
BitBlt : 511
[ D2D ] 988
Sprite 10 : 107.35 FPS ( 10)
Sprite 100 : 75.69 FPS ( 75)
Sprite 500 : 35.62 FPS ( 178)
Sprite 1000 : 21.07 FPS ( 210)
Sprite 5000 : 5.09 FPS ( 254)
Sprite 10000 : 2.61 FPS ( 261)
[ OGL ] 289
Scene 1 Score : 279
Lines (x1000) : ( 17754)
Scene 1 CPUs : ( 4)
Scene 2 Score : 10
Scene 2 CPUs : ( 1)
hamsterhead
Postby fbx » Sun May 24, 2009 5:04 am
This is what I like about forums. Even at the stock settings the numbers aren't hugely below the ASUS. And overclocked they're almost identical! Have you done longer term testing to see that it can sustain that overclock?
All this suggests that the early reviews are too pessimistic about the 751, do you agree? And what of the complaints about the keyboard flex (I know you mentioned this in your 1st vid) and the way the screen flexes and the other complaints.
Maybe you could do a "Next Week with the 751" video. I think the first two are getting a lot of play on youtube.
Anyway, much thanks for the figures.
Also, anyone else who runs CrystalMark -- please publish your results!
fbx
Postby P-Boss » Sun May 24, 2009 3:34 pm
hamsterhead wrote:ICS9LPRS365BGLF
THANK U SO MUCH
NOW IT WORKS!!
I run some test then i'll post my result
Did you succeed in trying gmabooster as well? I tried but it seems it doesn't work with the poulsubo chipset for now..
P-Boss
Postby P-Boss » Sun May 24, 2009 4:01 pm
ok my netbook running 133mhz reach a beautiful not convergent in sqr in super pi 1M.
It seems it need more vcore to run slightly at standard frequencies. Now i understand why acer put a 124 fsb for now in the factory bios. Maybe some of those cpu by intel doesn't reach neither standard frequencies at standard vcore. I hope they make a new bios with a little bit much vcore and standard frequencies
Superpi 1M at 1240mhz 2'05"
Superpi 1M at 1330 mhz 1'55"
P-Boss
Postby Phil72 » Sun May 24, 2009 8:22 pm
Great thread guys.
This is the first time I'm using SetFSB. Can someone tell me should I change the upper scale or the lower one?
Upper says 160/760. Lower says 325/760
As you can see I already changed the upper one a little bit. That went well.
Phil72
Postby dendielie » Mon May 25, 2009 5:02 pm
Has anyone tried any 3D games on the 751 like WoW on lowest settings...they say drivers are really bad,but maybe it's better now with the new ones?
dendielie
Return to Acer Aspire One 11.6" range
Users browsing this forum: Google [Bot] and 4 guests
